주요 콘텐츠로 건너뛰기
Acer Aspire 3003WLCi Internal Fan Replacement
Tristin Viale
Tristin Viale3 다른 기여자
최종 수정일 July 9, 2019
15 분
조정
In this guide, you will be instructed on how to replace the internal fan in your laptop. The internal fan helps to remove hot air from inside your laptop, keeping the internal components from overheating and causing damage to your laptop.
This replacement is of moderate difficulty, but will take you no more than fifteen minutes to complete. It requires very few tools, and can be completed in 6 steps.
필요한 것
도구
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Acer Aspire 3003WLCi Internal Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
  2. Acer Aspire 3003WLCi Internal Fan Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire 3003WLCi Internal Fan Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire 3003WLCi Internal Fan Replacement: 2 단계, 이미지 3개 중 3개
    • There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
    • Shift the bottom switch into an upward position in order to unlock the battery.
    • To unlock the upper switch, forcefully push the switch up and hold it in this position.
  3. Acer Aspire 3003WLCi Internal Fan Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire 3003WLCi Internal Fan Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
    • You may need to be a bit forceful when pulling the battery to the left if it hasn't been removed before.
    • You have to maintain pulling the upper switch upwards, or the battery will not come out.
  4. Acer Aspire 3003WLCi Internal Fan Replacement, Internal Fan: 4 단계, 이미지 1개 중 1개
    • The panel you will be removing to access the internal fan is located at the bottom of the laptop.
  5. Acer Aspire 3003WLCi Internal Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, unscrew the two 5mm captive screws on the panel.
    • The screws will not come out of the panel. This is intentional by the manufacturer.
  6. Acer Aspire 3003WLCi Internal Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Lift and remove the panel.
    • If you have difficulty removing the panel, use a spudger to pry the panel open.
  7. Acer Aspire 3003WLCi Internal Fan Replacement: 7 단계, 이미지 3개 중 1개 Acer Aspire 3003WLCi Internal Fan Replacement: 7 단계, 이미지 3개 중 2개 Acer Aspire 3003WLCi Internal Fan Replacement: 7 단계, 이미지 3개 중 3개
    • The fan is in the upper right corner of the panel.
    • Using a Phillips #00 screwdriver, remove each of the four 2.5mm screws securing the fan to the laptop.
  8. Acer Aspire 3003WLCi Internal Fan Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire 3003WLCi Internal Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the fan power cable from the motherboard by pulling the cable up and out of the connector.
  9. Acer Aspire 3003WLCi Internal Fan Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire 3003WLCi Internal Fan Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the fan by pulling it away from its surrounding copper.
    • The fan is secured on the other side of the copper by a piece of tape, so it may help to wiggle the fan multiple times to try and loosen the tape.
결론
작성자
3다른 기여자 명과 함께
Tristin Viale
회원 가입일: 03/25/19
675 평판
안내서 5개를 작성함
UMass Dartmouth, Team S2-G2, Bailey Spring 2019 UMass Dartmouth, Team S2-G2, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G2
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 219
