주요 콘텐츠로 건너뛰기
Acer Aspire 4520-5464 Keyboard Replacement
Hunter Gilcrease
Hunter Gilcrease3 다른 기여자
최종 수정일 January 5, 2018
5 - 10 분
조정
This guide will show you how to replace the keyboard of an Acer Aspire 4520-5464 laptop. The keyboard is used to type and use commands on the laptop.
필요한 것
도구
  1. Acer Aspire 4520-5464 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 4520-5464 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Keyboard Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
    • Remove the three 2mm Phillips #1 screws located at the top of the case's perimeter.
  5. Acer Aspire 4520-5464 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire 4520-5464 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the gray plastic section located above the keyboard using the prying tool.
    • Lift off of the keyboard.
  6. Acer Aspire 4520-5464 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire 4520-5464 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Take hold of the keyboard behind the function keys and lift gently.
    • Do not completely separate the keyboard from the laptop.
  7. Acer Aspire 4520-5464 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire 4520-5464 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Lift up the black locking tab located where the keyboard is attached to the laptop.
    • Pull the keyboard cable towards the trackpad and remove the keyboard.
결론
To reassemble your device, follow these instructions in reverse order using your new keyboard.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hunter Gilcrease
회원 가입일: 09/21/17
382 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 9
전체 시간: 683
