주요 콘텐츠로 건너뛰기
Acer Aspire 4520-5464 WiFi Wireless Card Replacement
Byeloth Hermanson
Byeloth Hermanson2 다른 기여자
최종 수정일 January 5, 2018
5 - 10 분
쉬움
더 나은 소개글
How to replace the WiFi Wireless Card of an Acer Aspire 4520-5464 laptop.
필요한 것
도구
  1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 2 단계, 이미지 2개 중 2개
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 3 단계, 이미지 1개 중 1개
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: 4 단계, 이미지 2개 중 1개 Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: 4 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the two 0.5mm screws from the smallest panel on the back of the computer.
    • Set the screws aside.
    • Lift up the panel using the indent located on the left side of the panel.
  5. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • Remove both the black and white wires by pinching the brass connectors and pulling up.
  6. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 0.5mm Phillips #1 black screws located on the WiFi card.
  7. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the WiFi card on the left side to remove it.
결론
To reassemble your device, follow these instructions in reverse order with a new WiFi wireless card.
작성자
2다른 기여자 명과 함께
Byeloth Hermanson
회원 가입일: 09/21/17
288 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 1,097
