주요 콘텐츠로 건너뛰기
Acer Aspire 5349-2592 Screen Replacement
Abderahmane Naidjate
Abderahmane Naidjate4 다른 기여자
최종 수정일 January 26, 2025
4 - 5 분
조정
더 많은 이미지가 필요함
If you are faced with a cracked, dirty, or old Acer Aspire 5349-2592 computer screen, use this guide to replace the LCD screen.
Replacing your own laptop screen can extend your devices life and over all save money in repairs.
This guide requires you to repeat the instructions in reverse order to reassemble device. Also be sure to power off the device before performing any of the steps below.
필요한 것
도구
  1. Acer Aspire 5349-2592 Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Open the laptop so that the screen is facing you.
  2. Acer Aspire 5349-2592 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Pull of the plastic frame of the laptop screen.
  3. Acer Aspire 5349-2592 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the 1/4'' screws at each of the corners using a Phillips screwdriver
    • Pull off the screen from the device. If necessary, you may use a bezel provided by the iFixit tool kit.
    • Handle the Acer 5349-2592 LCD hinges with care as they are delicate.
결론
작성자
4다른 기여자 명과 함께
회원 가입일: 04/03/19
547 평판
안내서 6개를 작성함
UMass Dartmouth, Team S1-G3, Simcock Spring 2019 UMass Dartmouth, Team S1-G3, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G3
4 회원들
안내서 8개를 작성함
1가이드 댓글
your description is extremely lacking, the two screws near the hinges, and connections.
ComputerGuy Wilkes-Barre - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 20
전체 시간: 667
