주요 콘텐츠로 건너뛰기
Acer Aspire 5534-1146 Hard Drive Replacement
Conner Burton
Conner Burton3 다른 기여자
최종 수정일 December 9, 2018
15 분
조정
더 나은 소개글
필요한 것
도구
  1. Acer Aspire 5534-1146 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Locate where the hard drive is located on the back side of the laptop and unscrew the two .8cm Long screws.
  2. Acer Aspire 5534-1146 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Once you have have removed the back panel cover, find the hard drive’s location.
  3. Acer Aspire 5534-1146 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Find and locate the two screws that are 0.8cm long that are holding the hard drive in place to the back metal plate.
    • Carefully take a PH #0 screwdriver and remove the two screws.
  4. Acer Aspire 5534-1146 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Once you have unscrewed the two screws, carefully slide the hard drive the opposite direction of the screws that you just removed, slide the drive till it is free.
    • You are now ready to remove the hard drive from it’s compartment from the device.
결론
작성자
3다른 기여자 명과 함께
Conner Burton
회원 가입일: 10/02/18
159 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 511
