Acer Aspire 5734z-4836 Fan Replacement
Cleaning the fan is an important part of laptop maintenance. The fan on the Acer Aspire 5734z-4836 is located under the circuit board, so you will first need to remove the battery, keyboard, and front panel.
Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
Begin with the laptop placed on its bottom and the empty keyboard space facing you.
다른 2명이 해당 안내서를 완성하였습니다.
