주요 콘텐츠로 건너뛰기
Acer Aspire 5742 Keyboard Replacement
Bill Murray
Bill Murray4 다른 기여자
최종 수정일 October 5, 2023
5 분
쉬움
커뮤니티-기여 안내서
Keyboard issues are common, thankfully this replacement is easy and should only take you 5 minutes to complete. It is very easy to break a key or to even spill something on to the keyboard.
If you are purchasing a replacement keyboard, make sure the one you buy is not only for the correct model of laptop, but also the correct nationality or you may find it has the wrong key layout or unexpected accented letters.
This guide will teach you how to replace this keyboard but there are very important details to remember. If you press to forcefully on the clips for the keyboard they will break. This goes the same for the locking ZIF connectors on the end of the ribbon cables. Along with this, do not fully remove the keyboard until you disconnect from the ZIF connectors. This will cause damage to the computer if you try to pull it out without completely disconnecting. If you have any further questions you can leave a comment and we will respond as quickly as possible!
필요한 것
도구
  1. Acer Aspire 5742 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Aspire 5742 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Aspire 5742 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Keyboard Replacement, Keyboard: 2 단계, 이미지 3개 중 1개 Acer Aspire 5742 Keyboard Replacement, Keyboard: 2 단계, 이미지 3개 중 2개 Acer Aspire 5742 Keyboard Replacement, Keyboard: 2 단계, 이미지 3개 중 3개
    • Unfold the laptop so that you are looking at the keyboard.
    • At the top right of the keyboard you will notice two clips above the 'Del' and 'End' keys.
    • Using your spudger, press these clips in to unlock the keyboard from the laptop
    • Be careful not to press too forcefully on these clips with the spudger as they may break
    • Slide the spudger along the top of the keyboard until the keyboard is able to easily be lifted up out of the laptop
    • Do NOT attempt to fully remove the keyboard as there is still a cable on its backside connected to the computer that can be damaged
  3. Acer Aspire 5742 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire 5742 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire 5742 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Now that the keyboard is outside of the laptop, you will see a ribbon cable coming from the back of the keyboard connected to the laptop.
    • To detach this cable you must use the pointed edge of the spudger to press down on the locking mechanisms on each side.
    • Do not use too much pressure when disconnecting the ZIF connector.
    • After unlocking both sides of the ZIF connector remove the keyboard for replacement.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bill Murray
회원 가입일: 10/24/16
593 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 UMass Dartmouth, Team 2-6, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G6
3 회원들
안내서 8개를 작성함
댓글 2개
Ik zie het vergrendelingsmechanisme bij stap drie niet. Wat ik ook naar beneden druk hij de kabel wil niet loslaten. Moet de klem misschien omhoog?
Hans Hendriks - 답글
Sehen Sie sich 케이블 커넥터 인식 및 분리 an. Möglicherweise gibt es eine Verriegelungsstange, die Sie anheben (Schritt 1) oder eine Stange, die Sie vorsichtig auf die andere Seite des Steckers drücken müssen (Schritt 7). Sobald Sie es ausgearbeitet haben, ist es einfach. (Beschuldigen Sie Google Translate, wenn dies keinen Sinn ergibt!)
Philip Le Riche - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 32
전체 시간: 6,747
