Acer Aspire 5750-6667 Keyboard Replacement
The keyboard on a laptop can often times be damaged easily from accidental water damage or stop functioning from over-use. The keyboard can be removed with the release of 6 tabs and by gently releasing an attached cable.
Turn the laptop right-side up and open the lid.
Locate the 6 black plastic tabs on the top edge of the keyboard that are holding the keyboard in place.
이 단계에 사용된 도구:Tweezers$4.99
Starting in one corner, use tweezers to push the tabs inward to release the keyboard and then use the tweezers to gently pry the keyboard up and away from the laptop.
Repeat this step to each of the 6 tabs along the top of the keyboard. Use your blue plastic opening tool to keep the released sections of the keyboard up.
다른 5명이 해당 안내서를 완성하였습니다.
