주요 콘텐츠로 건너뛰기
Acer Aspire E1-531 Wi-Fi Wireless Card Replacement
Sarah Brito
Sarah Brito9 다른 기여자
최종 수정일 May 18, 2022
15 - 30 분
조정
In this guide, we will be replacing the Wi-Fi wireless card for the Acer Aspire E1-531 laptop computer. A Wi-Fi wireless card is an important component within a laptop. If the Wi-Fi wireless card is broken or damaged, then the laptop will be unable to connect to wireless network.
Before starting this repair make sure that the Wi-Fi card is actually broken or damaged. Signs of a failing Wi-Fi wireless card include bad or no connection. However, you should also check that your network is online and there isn't an outage in the area.
Prior to starting this repair, be sure to power off your laptop and disconnect it from the power adapter.
필요한 것
도구
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  1. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement, Wi-Fi Wireless Card: 1 단계, 이미지 3개 중 1개 Acer Aspire E1-531 Wi-Fi Wireless Card Replacement, Wi-Fi Wireless Card: 1 단계, 이미지 3개 중 2개 Acer Aspire E1-531 Wi-Fi Wireless Card Replacement, Wi-Fi Wireless Card: 1 단계, 이미지 3개 중 3개
    • Flip your computer over and examine the back. Look for a bright orange switch, as shown in the pictures to the left.
    • Take the spudger and press against the orange switch and tart pushing the button to the left until it releases the battery.
  2. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: 2 단계, 이미지 1개 중 1개
    • Take out the battery completely.
  3. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: 3 단계, 이미지 2개 중 2개
    • Use the appropriate screw driver and remove screws to take off the back.
    • Take the opening tool and begin to pry open the back of the bottom cover like in Picture 2.
  4. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: 4 단계, 이미지 2개 중 2개
    • Once the back is off, the inside of the computer should be revealed, like the picture shown.
    • Identify the Wi-Fi wireless card.
  5. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • Grab the Wi-Fi card to "wiggle" it out of place.
    • Wiggle it out of place until the card is completely detached from the computer.
  6. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • Detach the connector from the computer to completely detach the Wi-Fi wireless card.
    • Once detached, take the new wireless card and follow these instructions in the reverse order.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Sarah Brito
회원 가입일: 06/06/16
140 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 25
전체 시간: 3,331
