주요 콘텐츠로 건너뛰기
Acer Aspire E3-111-C0WA Touchpad Replacement
Jonathan Chandler
Jonathan Chandler다른 한 명의 기여자
최종 수정일 December 20, 2017
15 분
조정
This guide will help you replace the touchpad on your computer.
필요한 것
도구
더보기...
  1. Acer Aspire E3-111-C0WA Touchpad Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Touchpad Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA Touchpad Replacement: 2 단계, 이미지 3개 중 3개
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Touchpad Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Touchpad Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA Touchpad Replacement: 4 단계, 이미지 3개 중 3개
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Touchpad Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Touchpad Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Touchpad Replacement, Touchpad: 7 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement, Touchpad: 7 단계, 이미지 2개 중 2개
    • Lift up on the black tab to release the ribbon cable from the touchpad.
    • Lightly pull on the blue tab to remove the cable from the connector.
  8. Acer Aspire E3-111-C0WA Touchpad Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement: 8 단계, 이미지 2개 중 2개
    • Peel up the silver tape adhering the touchpad cable to the case, revealing two screws underneath.
  9. Acer Aspire E3-111-C0WA Touchpad Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement: 9 단계, 이미지 2개 중 2개
    • Unscrew the three 6.2mm Phillips #1 screws holding the touchpad to the case.
  10. Acer Aspire E3-111-C0WA Touchpad Replacement: 10 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA Touchpad Replacement: 10 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA Touchpad Replacement: 10 단계, 이미지 3개 중 3개
    • Lift the touchpad assembly out of the case by its corners.
    • Slide the touchpad out of the chassis from under the speaker cable, taking care not to damage the cable.
    • Check to make sure the small strip of conductive tape connecting the copper pad on the PCB to the metal assembly is properly adhered.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jonathan Chandler
회원 가입일: 10/17/17
503 평판
안내서 4개를 작성함
UC Santa Barbara, Team S1-G2, Weedon Fall 2017 UC Santa Barbara, Team S1-G2, Weedon Fall 2017 회원
UCSB-WEEDON-F17S1G2
5 회원들
안내서 5개를 작성함
댓글 2개
Well made instruction, presumably works on all E3-111 devices; it did on my E3-111-C45G.
The spare parts number (Europe) is Acer No. TAA4329129, dubbed “Original Acer Touchpad / Touchboard silver Aspire E3-11 series”. Should cost around 22-25€.
ce re - 답글
In der Anleitung sollte zwingend erwähnt werden das jedes Silberne Tape (Tape conductive adhesive) wieder blasenfrei anzukleben ist. Wenn es eingerissen oder abgerissen ist dann ist es zu ersetzen weil es zur Erdung dient gerade im Bereich des Touchpads! Alternativ kann dann auch ein Kupfer Tape genutzt werden aber auch der Kleber auf dem Tape sollte elektrisch Leitfähig sein.
Black_B33tl3 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 1,044
