주요 콘텐츠로 건너뛰기
Acer Aspire E5-721-64T8 Hard Drive Replacement
Ed Herrera
Ed Herrera3 다른 기여자
최종 수정일 June 25, 2018
예상시간 없음
조정
If your laptop wont boot, it may be because of a corrupted hard drive. This simple guide will show you how to remove the hard drive for this laptop. Be sure to fallow the steps in order. In the end you will be able to remove and replace the current hard drive.
필요한 것
도구
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
더보기...
  1. Acer Aspire E5-721-64T8 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Acer Aspire E5-721-64T8 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1개 중 1개
    • Remove the four 3mm Phillips #0 screws from the hard drive.
  6. Acer Aspire E5-721-64T8 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF connector and remove the hard drive from the laptop.
결론
작성자
3다른 기여자 명과 함께
Ed Herrera
회원 가입일: 01/25/18
390 평판
안내서 3개를 작성함
USF Tampa, Team S7-G3, Passmore Spring 2018 USF Tampa, Team S7-G3, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G3
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 988
