Acer Aspire ES1-111M-C7DE Hard Drive Replacement
The hard drive is a relatively easy component to replace. That being said, you do have to be careful when removing it to not damage the connector.
Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
Locate the hard drive and slide the hard drive to the left until it disconnects from the mother board.
다른 3명이 해당 안내서를 완성하였습니다.
