주요 콘텐츠로 건너뛰기
Acer Aspire ES1-111M-C7DE RAM Replacement
Mason Devinney
Mason Devinney2 다른 기여자
최종 수정일 December 13, 2017
35 분
조정
To replace the RAM is an in-depth procedure as it's located under the motherboard. There are a lot of screws from the various parts but they're all the same size so it doesn't matter where they go back in.
필요한 것
도구
  1. Acer Aspire ES1-111M-C7DE RAM Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
  2. Acer Aspire ES1-111M-C7DE RAM Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire ES1-111M-C7DE RAM Replacement: 2 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, gently pry the lower case off. Place aside.
  3. Acer Aspire ES1-111M-C7DE RAM Replacement, Battery: 3 단계, 이미지 2개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Locate the small black button surrounded by a white circle near the battery on the motherboard.
    • Press and hold the button for five seconds.
  4. Acer Aspire ES1-111M-C7DE RAM Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire ES1-111M-C7DE RAM Replacement: 4 단계, 이미지 3개 중 3개
    • Using your fingers or the small plastic opening tools, disconnect the battery connection from the motherboard by pinching and pulling back on both sides of the connector.
  5. Acer Aspire ES1-111M-C7DE RAM Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire ES1-111M-C7DE RAM Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the two 6.2mm black screws holding the battery in place and unscrew them.
    • Gently lift and remove the battery.
  6. Acer Aspire ES1-111M-C7DE RAM Replacement, Hard Drive: 6 단계, 이미지 3개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement, Hard Drive: 6 단계, 이미지 3개 중 2개 Acer Aspire ES1-111M-C7DE RAM Replacement, Hard Drive: 6 단계, 이미지 3개 중 3개
    • Locate the hard drive and slide the hard drive to the left until it disconnects from the mother board.
  7. Acer Aspire ES1-111M-C7DE RAM Replacement, Network Card: 7 단계, 이미지 2개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement, Network Card: 7 단계, 이미지 2개 중 2개
    • You will see a white rectangular piece next to the upper left-hand corner of the motherboard that is connected with a black cord and a white cord; this is the network card.
    • Unscrew the one 6.2mm screw in the upper left-hand corner of the network card.
  8. Acer Aspire ES1-111M-C7DE RAM Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire ES1-111M-C7DE RAM Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the black and the white cords from the network card.
    • Slide the card out of the motherboard and replace it with the new one.
  9. Acer Aspire ES1-111M-C7DE RAM Replacement, RAM: 9 단계, 이미지 3개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement, RAM: 9 단계, 이미지 3개 중 2개 Acer Aspire ES1-111M-C7DE RAM Replacement, RAM: 9 단계, 이미지 3개 중 3개
    • Disconnect the remaining connectors from the motherboard.
  10. Acer Aspire ES1-111M-C7DE RAM Replacement: 10 단계, 이미지 2개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement: 10 단계, 이미지 2개 중 2개
    • Unscrew the three 6.2mm screws as indicated by the picture.
  11. Acer Aspire ES1-111M-C7DE RAM Replacement: 11 단계, 이미지 2개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement: 11 단계, 이미지 2개 중 2개
    • Flip the motherboard over.
  12. Acer Aspire ES1-111M-C7DE RAM Replacement: 12 단계, 이미지 1개 중 1개
    • Locate the RAM
  13. Acer Aspire ES1-111M-C7DE RAM Replacement: 13 단계, 이미지 3개 중 1개 Acer Aspire ES1-111M-C7DE RAM Replacement: 13 단계, 이미지 3개 중 2개 Acer Aspire ES1-111M-C7DE RAM Replacement: 13 단계, 이미지 3개 중 3개
    • Gently push the two metal clips that hold the RAM to the side, as indicated by the picture.
    • It should pop up once done.
  14. Acer Aspire ES1-111M-C7DE RAM Replacement: 14 단계, 이미지 1개 중 1개
    • Pull the RAM out.
결론
작성자
2다른 기여자 명과 함께
Mason Devinney
회원 가입일: 09/25/17
388 평판
안내서 3개를 작성함
USF Tampa, Team S3-G1, Cannon Fall 2017 USF Tampa, Team S3-G1, Cannon Fall 2017 회원
USFT-CANNON-F17S3G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 1,684
