주요 콘텐츠로 건너뛰기
Acer Aspire One 532h-2527 RAM Replacement
Jair Burgos
Jair Burgos3 다른 기여자
최종 수정일 September 6, 2019
4 분
조정
This guide will show how to remove the small back plate on your netbook. The removal of the plate is necessary to access your netbook’s RAM.
필요한 것
도구
  1. Acer Aspire One 532h-2527 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 RAM Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire One 532h-2527 RAM Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire One 532h-2527 RAM Replacement: 4 단계, 이미지 3개 중 3개
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 RAM Replacement, RAM: 5 단계, 이미지 1개 중 1개
    • Use the #0 Phillips Screw bit with the Screwdriver to remove the single 6mm Phillips screw from the small back plate.
  6. Acer Aspire One 532h-2527 RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool on the recessed notch at the bottom of the small plate to gently lift the plate up
  7. Acer Aspire One 532h-2527 RAM Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire One 532h-2527 RAM Replacement: 7 단계, 이미지 2개 중 2개
    • Once the plate becomes unhinged, gently rotate the plate to take it of of the device.
  8. Acer Aspire One 532h-2527 RAM Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire One 532h-2527 RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Using two fingers, gently spread the latches on the sides of the RAM card until the RAM card props up.
  9. Acer Aspire One 532h-2527 RAM Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire One 532h-2527 RAM Replacement: 9 단계, 이미지 2개 중 2개
    • Once the RAM card is propped up, carefully pull it out of its port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jair Burgos
회원 가입일: 09/15/16
425 평판
안내서 3개를 작성함
USF Tampa, Team 11-6, Blackwell Fall 2016 USF Tampa, Team 11-6, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G6
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 674
