주요 콘텐츠로 건너뛰기
Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement
John Hasenbein
John Hasenbein4 다른 기여자
최종 수정일 May 7, 2024
5 분
조정
더 나은 소개글
필요한 것
도구
  1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Power the laptop off.
    • Flip the laptop over and position it so the opening faces you.
    • Remove the rubber foot located near the opening side of the device using tweezers.
  2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the five 5-mm screws using the PH0 screwdriver.
  3. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 3 단계, 이미지 3개 중 3개
    • Identify the HDMI port located in the side of the laptop opposite to the power button.
    • Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
    • Pry along the laptop frame until the back panel comes loose.
    • Do not pull the back panel too hard as the battery is still connected to the back panel and the motherboard. This can damage your device.
  4. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Rotate the device so the opening faces you again.
    • Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
    • This screw is fastening the battery to the laptop.
    • Lift the back panel gently.
  5. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the cable that connects the battery to the motherboard.
    • Detach the back panel, which still includes the battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
John Hasenbein
회원 가입일: 09/11/17
119 평판
안내서 1개를 작성함
CSU Fullerton, Team S1-G4, Bruce Fall 2017 CSU Fullerton, Team S1-G4, Bruce Fall 2017 회원
CSUF-BRUCE-F17S1G4
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 1,038
