주요 콘텐츠로 건너뛰기
Acer Aspire One D255E Keyboard Replacement
Brian
Brian다른 한 명의 기여자
최종 수정일 September 16, 2019
예상시간 없음
조정
The keyboard is the most essential input component on a laptop. Though this component is designed to have frequent usage either with old age or bad treatment this component may have to be replaced. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
필요한 것
도구
  • Spudger
    Spudger
  1. Acer Aspire One D255E Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire One D255E Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire One D255E Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire One D255E Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brian
회원 가입일: 03/19/16
1,302 평판
안내서 5개를 작성함
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S16G8
2 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 22
지난 30일: 26
전체 시간: 2,481
