주요 콘텐츠로 건너뛰기
Acer Aspire R7-371T-72CF Power Port Replacement
Ethan Frey
Ethan Frey4 다른 기여자
최종 수정일 January 3, 2018
10 분
쉬움
If there is an issue with the charging port on your Acer Aspire, there might be an issue with the power connector. If your laptop is not charging or is charging irregularly, replacing the power connector might help alleviate these issues.
필요한 것
도구
  1. Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: 1 단계, 이미지 2개 중 1개 Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: 1 단계, 이미지 2개 중 2개
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Power Port Replacement: 2 단계, 이미지 1개 중 1개
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Power Port Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire R7-371T-72CF Power Port Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire R7-371T-72CF Power Port Replacement: 3 단계, 이미지 3개 중 3개
    • Locate the power connector, as shown on the left.
    • The power connector will be in the same location as where you normally plug the charger into the laptop to charge your device.
  4. Acer Aspire R7-371T-72CF Power Port Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire R7-371T-72CF Power Port Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire R7-371T-72CF Power Port Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the wiring from the motherboard, and pull out the rest of the wire carefully.
    • Make sure the wire is not caught on anything before pulling.
  5. Acer Aspire R7-371T-72CF Power Port Replacement: 5 단계, 이미지 1개 중 1개
    • Pull out the power connector by pulling upwards on the wires.
    • This may require a small amount of force, but should pop out with some pressure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ethan Frey
회원 가입일: 09/27/17
117 평판
안내서 1개를 작성함
Cal Poly, Team S8-G5, Banghart Fall 2017 Cal Poly, Team S8-G5, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G5
5 회원들
안내서 6개를 작성함
댓글 4개
What’s the part number for the power jack cable, and who sells it?
AcerFan - 답글
50.mqpn7.001 (SIQDD0ZS8AD001)
I found it here: https://www.itpartsource.com/50MQPN7001-...
Jorge Prado - 답글
What model is this? Is this the older (~2015) model with the small cylindrical charging port?
Sarah - 답글
The associated part id numbers for the Acer R7-371t 45W DC Jack Cable are:
50.MQPN7.001
SIQDD0ZS8AD001
Unfortunately, I have found this part impossible to find in stock at any source.
rosemank - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 1,773
