주요 콘텐츠로 건너뛰기
Acer Aspire R7-371T-72CF Wifi Chip Replacement
Dylan Meintser
Dylan Meintser3 다른 기여자
최종 수정일 January 3, 2018
5 분
조정
This guide will show you how to improve your wifi signal by replacing a weak or broken wifi chip.
필요한 것
도구
  1. Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: 1 단계, 이미지 2개 중 1개 Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: 1 단계, 이미지 2개 중 2개
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 2 단계, 이미지 1개 중 1개
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 3 단계, 이미지 3개 중 3개
    • Locate the wifi chip, as shown to the left.
    • The chip can by identified by the white and black wires connected to it, as well as a single screw holding it in place.
  4. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 4 단계, 이미지 3개 중 3개
    • Locate the 2 antenna wires connected to the chip.
    • One is black, and the other is white.
    • Use a spudger or plastic opening tool to carefully disconnect the wires from the chip by prying upwards.
    • The connectors 'click' into place, like a button.
  5. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire R7-371T-72CF Wifi Chip Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the Phillips #00 6mm securing screw using your screwdriver.
  6. Acer Aspire R7-371T-72CF Wifi Chip Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the chip by pulling towards the edge of the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dylan Meintser
회원 가입일: 09/27/17
476 평판
안내서 4개를 작성함
Cal Poly, Team S8-G5, Banghart Fall 2017 Cal Poly, Team S8-G5, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G5
5 회원들
안내서 6개를 작성함
댓글 한 개
Any idea on screen replacement for this particular model? I’ve been searching for a video all week. Please help me out if possible
Hasan Mahmood - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 570
