주요 콘텐츠로 건너뛰기
Acer Aspire TimelineX 4830T-6682 Keyboard Replacement
Tai H Nguyen
Tai H Nguyen3 다른 기여자
최종 수정일 May 16, 2024
10 분
조정
This is the keyboard replacement guide for the Acer Aspire TimelineX 4830T-6682. Make sure you have followed all of the prerequisite steps before proceeding!
필요한 것
도구
더보기...
  1. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement, Lower Back Panel: 1 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 4830T-6682 Keyboard Replacement, Lower Back Panel: 1 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 4830T-6682 Keyboard Replacement, Lower Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement, Keyboard: 2 단계, 이미지 1개 중 1개
    • Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
  3. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
    • Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
  4. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Next, disconnect the 4 wired tapes of the keyboard from the motherboard just like we did with the lower front touchpad panel.
  5. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Finally, using an opening tool, gently pry along the edge of the keyboard to separate it from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tai H Nguyen
회원 가입일: 09/25/17
260 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 1,859
