주요 콘텐츠로 건너뛰기
Acer Aspire V3-572-746F Touchpad Replacement
Terry Hobbs
Terry Hobbs3 다른 기여자
최종 수정일 July 26, 2024
1 시간
조정
커뮤니티-기여 안내서
Touchpad microswitch was performing badly. Checked for driver updates and then went for replacing the touchpad itself.
필요한 것
부품
도구
더보기...
  1. Acer Aspire V3-572-746F Touchpad Replacement, Remove Back Screws: 1 단계, 이미지 1개 중 1개
    • Remove battery by sliding button (Yellow)
    • Remove all screws (Red)
  2. Acer Aspire V3-572-746F Touchpad Replacement, Removing keyboard & front cover: 2 단계, 이미지 2개 중 1개 Acer Aspire V3-572-746F Touchpad Replacement, Removing keyboard & front cover: 2 단계, 이미지 2개 중 2개
    • Carefully prise up the silver top cover including the keyboard.It includes the silver surround and the black hinge covers. It clips off. Do not fully remove yet.
    • Carefelly remove the 3 ribbon connectors. The Black arrow connector is loosened by hinging the black tab towards you. The Yellow arrow connector is removed by pushing the 2 cream tabs forward.
  3. Acer Aspire V3-572-746F Touchpad Replacement, Remove 3rd ribbon & keyboard: 3 단계, 이미지 1개 중 1개
    • The 3rd connector ribbon is removed by lifting up the cream tab (Picture shows it in up position.
    • The keyboard & touchpad should then lift off.
    • Carefully remove the earth straps (Yellow) from the touch pad. I was able to simply stick them back down.
    • Remove the 3 screws (Red) and the touch pad lift out. I forgot to swap over te blue tabs that weren't attached to the new touchpad, so probably best to remember. My photo wasn't good enough quality to upload.
결론
작성자
3다른 기여자 명과 함께
Terry Hobbs
회원 가입일: 01/03/19
109 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 828
