주요 콘텐츠로 건너뛰기
Acer Aspire V5-122P-0468 Display Replacement
Nat McCormick
Nat McCormick4 다른 기여자
최종 수정일 April 12, 2022
30 분 - 1 시간
어려움
If the display is malfunctioning on your Acer Aspire V5-122P-0468 laptop follow this guide to replace it yourself.
필요한 것
도구
더보기...
  1. Acer Aspire V5-122P-0468 Display Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0468 Display Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Display Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0468 Display Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Display Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0468 Display Replacement: 3 단계, 이미지 2개 중 2개
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Display Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire V5-122P-0468 Display Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire V5-122P-0468 Display Replacement: 4 단계, 이미지 3개 중 3개
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Display Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire V5-122P-0468 Display Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire V5-122P-0468 Display Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Display Replacement, Display: 6 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0468 Display Replacement, Display: 6 단계, 이미지 2개 중 2개
    • Flip up the black locking tab on the ZIF connector, and pull out the ribbon cable.
  7. Acer Aspire V5-122P-0468 Display Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0468 Display Replacement: 7 단계, 이미지 2개 중 2개
    • Wedge a spudger in between the plastic bezel frame and back cover to create a gap.
    • Then insert a plastic opening tool to pry apart the bezel from the back cover.
    • Work your way around the perimeter of the cover with the plastic opening tool.
  8. Acer Aspire V5-122P-0468 Display Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0468 Display Replacement: 8 단계, 이미지 2개 중 2개
    • Open up the laptop to unsnap the hinges from the back of the computer.
    • Slide the pin connector and cable through the hinge that connects the display to the rest of the laptop.
  9. Acer Aspire V5-122P-0468 Display Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0468 Display Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the transparent tape covering the pin connector.
    • Unplug the pin connector from the display.
  10. Acer Aspire V5-122P-0468 Display Replacement: 10 단계, 이미지 1개 중 1개
    • Cut the tape between the display and the plastic frame using the flat end of a spudger.
    • Work the spudger around the perimeter of the display to separate it from the bezel.
    • The display is attached with a strong adhesive. Applying heat with a hairdryer or heat gun may make the removal process easier.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nat McCormick
회원 가입일: 02/15/18
801 평판
안내서 5개를 작성함
USF Tampa, Team S16-G1, Boczar Spring 2018 USF Tampa, Team S16-G1, Boczar Spring 2018 회원
USFT-BOCZAR-S18S16G1
5 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 19
전체 시간: 1,112
