주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2629 RAM Replacement
Nicholas Vassiliadis
Nicholas Vassiliadis4 다른 기여자
최종 수정일 April 25, 2022
5 분
쉬움
This guide will provide in-depth instructors on replacing or removing the RAM in an Acer Aspire V5-131-2629 laptop.
Is your laptop slow and sluggish while performing small tasks? Replacing and upgrading your RAM can increase the speed of your laptop for easy multitasking. Getting more RAM will boost the overall performance of your laptop. Follow this simple 6 step guide to replace your RAM and give your computer a boost in no time!
Unfortunately, the Acer website has taken down information regarding this device. However, a basic, rather informal summary of the details and specs can be found at the following link:
++Acer Aspire V5-131-2629 prices and specs++
A general disassembly tutorial of the device can be found:
++How to Disassemble the Acer Aspire V5 131++
Outside Resources-
The link to replacement RAM can be found at:
++Acer Aspire V5 131-2629 RAM Replacement++
필요한 것
도구
  1. Acer Aspire V5-131-2629 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 RAM Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 RAM Replacement: 4 단계, 이미지 2개 중 2개
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 RAM Replacement, Cover: 5 단계, 이미지 1개 중 1개
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 RAM Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 RAM Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 RAM Replacement, RAM: 7 단계, 이미지 1개 중 1개
    • Using your finger, press the small tab on each side of the memory card.
    • The memory card will eject at a 45 degree angle.
  8. Acer Aspire V5-131-2629 RAM Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the memory cards out from the laptop.
결론
작성자
4다른 기여자 명과 함께
회원 가입일: 10/25/19
85 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G3
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 21
전체 시간: 697
