주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2680 Battery Replacement
Naomi Zaldana
Naomi Zaldana다른 한 명의 기여자
최종 수정일 December 28, 2022
3 분
쉬움
If your Acer Aspire V5 is not charging due to a faulty or dead battery, use this guide to replace your battery. Check for signs of a faulty battery which may include dents, corrosion along the sides, or bloating. Your battery provides power to your laptop, enabling the device to work without a power cord. However, eventually, you will need to charge the battery, making it essential to replace dead or faulty batteries as soon as possible.
Before using this guide, inspect that the battery is correctly placed in the battery slot or attempt a power reset. You can refer to our troubleshooting guide with instructions on how to perform a power reset under "Laptop Not Starting Up."
If you have identified that you have a dead or faulty battery, please proceed with the instructions in this guide. You will need an opening tool to complete this process.
Before beginning, make sure to close, power off your laptop completely, and disconnect from any external power source.
필요한 것
도구
  1. Acer Aspire V5-131-2680 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Battery Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2680 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2680 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • In front of the battery, you will find a sliding flap. This is a battery-release lock.
    • Place your finger on the latch and slide the latch to open. Pull out the battery from its compartment.
    • Do not remove your finger from the latch while sliding the battery out.
    • Once the battery is out, release the latch.
결론
작성자
1다른 기여자 명과 함께
Naomi Zaldana
회원 가입일: 09/26/22
147 평판
안내서 1개를 작성함
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 269
