주요 콘텐츠로 건너뛰기
Acer Aspire V5-571 Mother Board Replacement
ZFix
ZFix2 다른 기여자
최종 수정일 April 21, 2022
30 - 35 분
어려움
커뮤니티-기여 안내서
How to disassemble and remove the Mother / Main Board.
____________________________________________________________________
필요한 것
도구
더보기...
동영상 개요
  1. Acer Aspire V5-571 Mother Board Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Mother Board Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Mother Board Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
    The two clips push toward the space-bar part of the keyboard. There are further clips around the edge of the keyboard, but it can be removed by careful prying with a thin blade screwdriver.
    ENT - 답글
  2. Acer Aspire V5-571 Mother Board Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Mother Board Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Mother Board Replacement: 2 단계, 이미지 3개 중 3개
    It would be helpful to have more info on how to remove the two cables. The larger one has a couple of clips that slide, but what exactly comes off? Do the plastic strips lift, or do the flat cables just pull out of them? Don't want to break something!
    ENT - 답글
    I watched several videos, many of which had the action hidden behind the keyboard. The larger ribbon pulls out of the strip after the two white clips on the end are moved. The smaller one has a black strip which lifts from the ribbon side, releasing the cable.
    ENT - 답글
  3. Acer Aspire V5-571 Mother Board Replacement, Optical Drive: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Mother Board Replacement, Optical Drive: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Mother Board Replacement, Optical Drive: 3 단계, 이미지 3개 중 3개
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Mother Board Replacement, Upper  Cover: 4 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Mother Board Replacement, Upper  Cover: 4 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Mother Board Replacement, Upper  Cover: 4 단계, 이미지 3개 중 3개
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
    After removing the 18x Phillips screws, the laptop is VERY fragile in the hinge area. The bottom cover will easily crack or break in the hinge area when opening the laptop with no screws, particularly the left side near the power button. Possibly this step should be revised to recommend opening the laptop 90 degrees before removing the 18x screws. Or, advise extreme caution when opening the laptop with no screws.
    jonnyquest - 답글
    Hi, do you know where buy screws that you mention in step 4? “Remove 18x Phillips screws from the bottom cover.”
    I am italian. Thank you anyway.
    Sara Caruso - 답글
    The laptop I have included 6x screws from inside and 16x screws from the bottom. This seems to be a minor variation from model to model.
    William Fulton - 답글
    Same with my model @sara Caruso. The six of them, and the two to release the keyboard, are shorter than the 18. All the screws had blue locktite on them.
    ENT - 답글
  5. Acer Aspire V5-571 Mother Board Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Mother Board Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Mother Board Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully separate the upper cover and remove it.
    In my unit, there was also a screw holding the DVD drive in place, just toward the center from the drive itself. This screw also had to be removed to be able to remove the upper cover
    Ken Hill - 답글
  6. Acer Aspire V5-571 Mother Board Replacement, HDD (Hard Disk Drive): 6 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Mother Board Replacement, HDD (Hard Disk Drive): 6 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Mother Board Replacement, HDD (Hard Disk Drive): 6 단계, 이미지 3개 중 3개
  7. Acer Aspire V5-571 Mother Board Replacement, Wi-Fi Half Mini PCIe card: 7 단계, 이미지 2개 중 1개 Acer Aspire V5-571 Mother Board Replacement, Wi-Fi Half Mini PCIe card: 7 단계, 이미지 2개 중 2개
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 Mother Board Replacement, Mother Board: 8 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Mother Board Replacement, Mother Board: 8 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Mother Board Replacement, Mother Board: 8 단계, 이미지 3개 중 3개
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 Mother Board Replacement: 9 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Mother Board Replacement: 9 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Mother Board Replacement: 9 단계, 이미지 3개 중 3개
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 Mother Board Replacement: 10 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Mother Board Replacement: 10 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Mother Board Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully pick up the Mother board and disconnect the Battery cable.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 한 개
I can’t seem to get the system to reboot after replacing two motherboards. Is there a little trick about replacing or reseating the motherboard properly? Is the black cloth tape over the fan exhaust important?
Fun Fong - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 24
전체 시간: 4,456
