주요 콘텐츠로 건너뛰기
Acer Aspire V5-571-6889 Hard Drive Replacement
Joe Niu
Joe Niu6 다른 기여자
최종 수정일 June 18, 2022
30 분
조정
This guide will show you step-by-step instructions for replacing the display assembly. Removing the hard drive is not necessary, step 6, for completing this task. Also, make sure the unit is powered down before performing any of the following tasks.
필요한 것
부품
도구
더보기...
  1. Acer Aspire V5-571-6889 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Hard Drive Replacement, Remove Upper Cover: 5 단계, 이미지 1개 중 1개
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Joe Niu
회원 가입일: 09/20/17
628 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 730
