주요 콘텐츠로 건너뛰기
Acer Aspire V5-571P-6815 Touchscreen Replacement
Brianna Sinder
Brianna Sinder5 다른 기여자
최종 수정일 May 7, 2024
예상시간 없음
조정
A guide on how to replace the touchscreen on a Acer Aspire V5-571P-6815 laptop.
필요한 것
도구
더보기...
  1. Acer Aspire V5-571P-6815 Touchscreen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Touchscreen Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-571P-6815 Touchscreen Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Touchscreen Replacement, Touchscreen: 3 단계, 이미지 2개 중 1개 Acer Aspire V5-571P-6815 Touchscreen Replacement, Touchscreen: 3 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool between the screen and lid.
    • Work the plastic opening tool around the perimeter while prying upwards until the screen separates from the lid.
  4. Acer Aspire V5-571P-6815 Touchscreen Replacement: 4 단계, 이미지 1개 중 1개
    • Lay the screen flat down on the keyboard.
  5. Acer Aspire V5-571P-6815 Touchscreen Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire V5-571P-6815 Touchscreen Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the camera using a pair of blunt nose tweezers.
    • Peel up the adhesive tape keeping the camera's cable tied down.
  6. Acer Aspire V5-571P-6815 Touchscreen Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire V5-571P-6815 Touchscreen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the microphone from the motherboard with a pair of blunt nose tweezers.
    • Slide out the adhesive tape securing the microphone cable.
  7. Acer Aspire V5-571P-6815 Touchscreen Replacement: 7 단계, 이미지 3개 중 1개 Acer Aspire V5-571P-6815 Touchscreen Replacement: 7 단계, 이미지 3개 중 2개 Acer Aspire V5-571P-6815 Touchscreen Replacement: 7 단계, 이미지 3개 중 3개
    • Lift up the ribbon cable contained by the adhesive strip with blunt nose tweezers.
    • This will allow you to access the two black digitizer ribbons.
    • Use a spudger to flip up the retaining flap on the digitizer ribbon cable ZIF socket.
    • Pull the ribbon cables out of their sockets.
  8. Acer Aspire V5-571P-6815 Touchscreen Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire V5-571P-6815 Touchscreen Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the board from the laptop.
  9. Acer Aspire V5-571P-6815 Touchscreen Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire V5-571P-6815 Touchscreen Replacement: 9 단계, 이미지 2개 중 2개
    • Use the blunt nose tweezers to peel up the adhesive on the display cable.
    • Pull on the adhesive tape to disconnect the display from the motherboard.
  10. Acer Aspire V5-571P-6815 Touchscreen Replacement: 10 단계, 이미지 2개 중 1개 Acer Aspire V5-571P-6815 Touchscreen Replacement: 10 단계, 이미지 2개 중 2개
    • Lift the whole strip connected to the circuit board and LCD connector. Place the strip to the side where it is not in contact with the screen.
    • Remove the whole screen from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brianna Sinder
회원 가입일: 04/12/18
377 평판
안내서 2개를 작성함
UW Tacoma, Team S1-G4, Liner Spring 2018 UW Tacoma, Team S1-G4, Liner Spring 2018 회원
UWT-LINER-S18S1G4
5 회원들
안내서 8개를 작성함
댓글 한 개
The heading of your Procedure is “Acer Aspire V5-571P-6815 Touchscreen Replacement” BUT you just opened up the entire screen.
NOTE: you didn’t separate the “TOUCH SCREEN” from the LCD screen.
This supposed to be the most important part of your procedure item ! ! ! !
PLEASE……. ******
KaivitiSingh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 25
전체 시간: 3,597
