주요 콘텐츠로 건너뛰기
Acer Aspire V5-591G-75KE Hard Drive Replacement
Reina Godeck
Reina Godeck4 다른 기여자
최종 수정일 April 19, 2022
5 - 10 분
조정
The Acer Aspire V5-591G-75KE is manufactured with a Seagate 1 TB 2.5-Inch SATA III 5400rpm Hard Drive.
If you replace the hard drive, make sure it observes the 2.5-Inch dimensions in order to use the rubber mounting brackets that secure the drive in place.
필요한 것
부품
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: 1 단계, 이미지 3개 중 1개 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: 1 단계, 이미지 3개 중 2개 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: 1 단계, 이미지 3개 중 3개
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-591G-75KE Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire V5-591G-75KE Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire V5-591G-75KE Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire V5-591G-75KE Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: 5 단계, 이미지 3개 중 1개 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: 5 단계, 이미지 3개 중 2개 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: 5 단계, 이미지 3개 중 3개
    • Using the plastic tabs, lift the hard drive slightly and pull to the left.
    • Remove the rubber mounting brackets from the hard drive.
    • If you are replacing your hard drive with a new one, please note you will need to reuse the rubber mounting brackets in order to secure it in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Reina Godeck
회원 가입일: 10/16/17
741 평판
안내서 5개를 작성함
UW Tacoma, Team S3-G5, Liner Fall 2017 UW Tacoma, Team S3-G5, Liner Fall 2017 회원
UWT-LINER-F17S3G5
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 1,196
