주요 콘텐츠로 건너뛰기
Acer Aspire V5-591G-75KE Wireless Card Replacement
Tasier Hagler
Tasier Hagler3 다른 기여자
최종 수정일 May 16, 2024
5 - 10 분
조정
The Acer Aspire V5-591G-75KE is manufactured with a Qualcomm Atheros NFA344A wireless card.
필요한 것
부품
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: 1 단계, 이미지 3개 중 1개 Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: 1 단계, 이미지 3개 중 2개 Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: 1 단계, 이미지 3개 중 3개
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Wireless Card Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-591G-75KE Wireless Card Replacement: 2 단계, 이미지 2개 중 2개
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Wireless Card Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire V5-591G-75KE Wireless Card Replacement: 3 단계, 이미지 2개 중 2개
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Wireless Card Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire V5-591G-75KE Wireless Card Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire V5-591G-75KE Wireless Card Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Wireless Card Replacement, Wireless Card: 5 단계, 이미지 1개 중 1개
    • Locate the wireless card on the top left quadrant. It should have two antenna cables connected to it, one white and one black.
  6. Acer Aspire V5-591G-75KE Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • With a pair of blunt tweezers, firmly grasp each antenna head and detach it by lifting straight up.
    • The antenna cables are connected through small sockets. Small popping sounds when attaching and detaching the antennas are normal.
    • Note that the white cable connects on the top socket.
  7. Acer Aspire V5-591G-75KE Wireless Card Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire V5-591G-75KE Wireless Card Replacement: 7 단계, 이미지 2개 중 2개
    • Using a Phillip Head size 1 screwdriver, remove the screw attaching the wireless card to the laptop frame.
    • To detach the wireless card, lift up slightly and pull away.
결론
작성자
3다른 기여자 명과 함께
Tasier Hagler
회원 가입일: 10/18/17
428 평판
안내서 4개를 작성함
UW Tacoma, Team S3-G5, Liner Fall 2017 UW Tacoma, Team S3-G5, Liner Fall 2017 회원
UWT-LINER-F17S3G5
4 회원들
안내서 18개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 30
전체 시간: 1,415
