주요 콘텐츠로 건너뛰기
Acer Chromebook 15 C910-C453 Speakers Replacement
Jacob Rakestraw
Jacob Rakestraw3 다른 기여자
최종 수정일 October 14, 2019
10 분
조정
Use this guide to replace the speakers.
필요한 것
부품
도구
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
더보기...
  1. Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Speakers Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Speakers Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Speakers Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: 6 단계, 이미지 3개 중 1개 Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: 6 단계, 이미지 3개 중 2개 Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: 6 단계, 이미지 3개 중 3개
    • Before beginning hard drive replacement, the back cover should be taken off and the battery removed to ensure no power is connected.
    • Carefully eject the black ribbon from the white base by squeezing inward at the base and gently pulling backwards.
    • Gently pull black ribbon out.
  7. Acer Chromebook 15 C910-C453 Speakers Replacement: 7 단계, 이미지 3개 중 1개 Acer Chromebook 15 C910-C453 Speakers Replacement: 7 단계, 이미지 3개 중 2개 Acer Chromebook 15 C910-C453 Speakers Replacement: 7 단계, 이미지 3개 중 3개
    • Disconnect the black wires where the speakers are connected to the motherboard by pulling down on both sides with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Speakers Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Speakers Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pull the right speaker, FYHZRF-R, upward, unlatching it from its 2 rubber joints.
    • Repeat with left speaker, FYHZRF-L.
  9. Acer Chromebook 15 C910-C453 Speakers Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Speakers Replacement: 9 단계, 이미지 2개 중 2개
    • Lift left and right speakers up and untangle the connecting wire from the metal notches.
    • Remove the speakers.
결론
작성자
3다른 기여자 명과 함께
Jacob Rakestraw
회원 가입일: 04/17/17
419 평판
안내서 4개를 작성함
Cal Poly, Team S15-G1, Banghart Spring 2017 Cal Poly, Team S15-G1, Banghart Spring 2017 회원
CPSU-BANGHART-S17S15G1
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 640
