주요 콘텐츠로 건너뛰기
Acer Chromebook C731-C8VE Display Assembly Replacement
Justin Menninger
Justin Menninger3 다른 기여자
최종 수정일 October 19, 2022
5 분
조정
This is the display assembly replacement guide for the Acer Chromebook C731-C8VE. By following the guide, you should be able to completely remove the screen from your device.
Make sure to follow all hazard warnings for your safety.
필요한 것
도구
  1. Acer Chromebook C731-C8VE Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1개 중 1개
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Display Assembly Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C731-C8VE Display Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • The 2 mm screws marked orange have washers attached and must be placed in these specific areas.
    • These 2 mm screws do not have washers and will be located on the left and right of the device.
  3. Acer Chromebook C731-C8VE Display Assembly Replacement: 3 단계, 이미지 3개 중 1개 Acer Chromebook C731-C8VE Display Assembly Replacement: 3 단계, 이미지 3개 중 2개 Acer Chromebook C731-C8VE Display Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Display Assembly Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook C731-C8VE Display Assembly Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook C731-C8VE Display Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Use the JIS #00 screwdriver to remove the four 1.5mm screws that connect the base of the laptop to the screen. There are two screws on each latch.
    • Carefully detach the cables that connect the screen to the motherboard. This includes a black display cable that connects to the mother board and two wires that connect to the Wi-Fi card.
  5. Acer Chromebook C731-C8VE Display Assembly Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook C731-C8VE Display Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Do this step slowly to ensure that you do not damage the screen or the motherboard.
    • Remove the screen from the base of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Justin Menninger
회원 가입일: 03/21/22
400 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 5
전체 시간: 313
