주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-431-C5EX Wireless Card Replacement
Holden Kurfess
Holden Kurfess5 다른 기여자
최종 수정일 July 5, 2022
5 - 10 분
조정
This repair guide is designed to instruct you on how to replace the wireless adapter in your Chromebook. All you will need for this replacement is a Phillips #0 screwdriver and a plastic spudger. Remember to completely power down your Chromebook before working on it, and handle the internal components of you Chromebook with care as they are fragile.
필요한 것
도구
  1. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Bottom Panel: 1 단계, 이미지 1개 중 1개
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1개 중 1개
    • Remove the 4mm Phillips #0 screw securing the wireless adapter to the main circuit board.
  5. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • Unplug the Wireless adapter from the main circuit board by giving the adapter light pressure and sliding it out of its port.
  6. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • Detach the two cables from the Adapter by pulling directly up on them, and then remove the adapter.
    • Note that the black cable is already detached in this photo to show what it looks like with the cables removed.
    • Be sure to note the original locations of the black and white cables when installing the new wireless adapter.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Holden Kurfess
회원 가입일: 04/18/17
367 평판
안내서 1개를 작성함
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G3
5 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 25
전체 시간: 1,607
