주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-532-C47C Battery Replacement
필요한 것
  1. Acer Chromebook CB3-532-C47C Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Battery Replacement: 2 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Battery Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Battery Replacement, Remove the battery cable: 3 단계, 이미지 1/1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Battery Replacement, Battery: 4 단계, 이미지 1/2 Acer Chromebook CB3-532-C47C Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the laptop.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 3명이 해당 안내서를 완성하였습니다.
Sadie Brown
회원 가입일: 10/25/21
967 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 31
전체 시간: 1,429
