주요 콘텐츠로 건너뛰기
Acer Chromebook CB5-132T-C8ZW USB Port Replacement
Lauren Reichenbach
Lauren Reichenbach4 다른 기여자
최종 수정일 June 18, 2020
2 분
쉬움
Before beginning, make sure the Acer Chromebook CB5-132T-C8ZW is disconnected from any external power source; then press and hold the power button for at least five seconds prior to dismantling in order to release any stored energy that could potentially be harmful.
필요한 것
도구
  • JIS #1
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
더보기...
  1. Acer Chromebook CB5-132T-C8ZW USB Port Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove eleven 7.2 mm screws from the bottom of the Chromebook using a JIS #1 screwdriver.
  2. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 2 단계, 이미지 2개 중 2개
    • Insert and slightly twist a plastic opening tool to separate and remove the backing of the Chromebook from the body.
    • Do not immediately remove the back from the laptop. The power strip keeps the backing attached to the rest of the laptop. Gently lift backing from the power button side and set next to the body of the laptop.
  3. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 3 단계, 이미지 2개 중 2개
    • Remove two 4.6 mm JIS # screws at each end of the battery.
  4. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully pull out the ribbon cable attached to the motherboard that runs wires to the battery.
    • Remove the battery.
  5. Acer Chromebook CB5-132T-C8ZW USB Port Replacement, USB Port: 5 단계, 이미지 2개 중 1개 Acer Chromebook CB5-132T-C8ZW USB Port Replacement, USB Port: 5 단계, 이미지 2개 중 2개
    • From the back panel, remove one 3.4 mm JIS #1 screw.
  6. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the white connector strip using your fingers.
  7. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the USB port up using a spudger.
    • Remove the USB port with your fingers.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Lauren Reichenbach
회원 가입일: 01/13/20
580 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 5
전체 시간: 572
