주요 콘텐츠로 건너뛰기
Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement
Lauryn F
Lauryn F2 다른 기여자
최종 수정일 January 6, 2025
20 - 25 분
조정
If several keys or the mouse/touch pad are unresponsive, or the entire keyboard on your Acer Chromebook (Spin 511 (C741L) N20Q8) stops registering your input, then a replacement is needed to be fully functional again.
Ensure that your laptop is powered down for this replacement, then follow this guide.
필요한 것
도구
더보기...
  1. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
  2. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
  3. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement, Battery: 3 단계, 이미지 3개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement, Battery: 3 단계, 이미지 3개 중 2개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Gently remove the electrical tape from the battery.
    • Detach the colored wires from the wire connector on the motherboard.
    • Remove the battery from the laptop.
  4. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Remove the six 2.4 mm screws from the hinges using a Phillips #1 screwdriver.
  5. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Flip up the hinges on each side that were previously secured down by the screws.
  6. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the tape from the black connector and gently remove it from the socket.
  7. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Detach the connector from the motherboard.
    • Carefully remove the pin connector containing the black, white, and red wires from its socket.
  8. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully remove the blue, yellow, and black wires from their connectors.
  9. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the long connector from the socket.
  10. Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 10 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Keyboard Replacement: 10 단계, 이미지 2개 중 2개
    • Gently pull and remove the keyboard from the screen.
결론
작성자
2다른 기여자 명과 함께
Lauryn F
회원 가입일: 09/26/24
710 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 32
전체 시간: 94
