주요 콘텐츠로 건너뛰기
Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement
Lauryn F
Lauryn F3 다른 기여자
최종 수정일 January 13, 2025
15 - 20 분
조정
추천 학생 안내서
The motherboard is the main circuit board of the Acer Chromebook (Spin 511 (C741L) N20Q8), providing power to each part of the laptop in order to communicate and turn on. With a faulty motherboard, the Chromebook may shut down randomly or not even power on. If this happens, a replacement of the motherboard is needed in order for the device to work again.
Make sure to power down your device and disconnect from any power sources before you begin.
필요한 것
도구
더보기...
  1. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
  2. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
  3. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: 3 단계, 이미지 3개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: 3 단계, 이미지 3개 중 2개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Gently remove the electrical tape from the battery.
    • Detach the colored wires from the wire connector on the motherboard.
    • Remove the battery from the laptop.
  4. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Remove the six 2.4 mm screws from the hinges using a Phillips #1 screwdriver.
    • Flip the gray hinges up.
  5. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two metal plates that were previously held down by each hinge.
  6. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Detach the connector from the motherboard.
  7. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Gently remove the blue, yellow, and black wires from their connectors.
  8. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the tape from the black connector and gently remove it from the socket.
  9. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully remove the pin connector containing the black, white, and red wires from its socket.
  10. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Detach the long connector from the socket.
    • Remove the motherboard from the device.
결론
작성자
3다른 기여자 명과 함께
Lauryn F
회원 가입일: 09/26/24
710 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 20
전체 시간: 96
