주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-53-52FA CMOS Replacement
Alfredo Prieto
Alfredo Prieto2 다른 기여자
최종 수정일 June 10, 2024
20 분
쉬움
Use this guide to replace the CMOS in the Acer Nitro 5 AN515-53-52FA laptop. Before doing this guide please make sure there is no external power connected and that nothing is on.
The CMOS battery is a separate small battery that keeps track of time regardless if things are powered on or off. A great indicator to when it needs a replacement is when the clock on your PC falls behind. When disposing the broken CMOS please dispose it by trusted source and not a false company.
필요한 것
도구
  1. Acer Nitro 5 AN515-53-52FA CMOS Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA CMOS Replacement: 2 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA CMOS Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA CMOS Replacement: 3 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA CMOS Replacement: 3 단계, 이미지 2개 중 2개
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA CMOS Replacement: 4 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA CMOS Replacement: 5 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA CMOS Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA CMOS Replacement: 6 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA CMOS Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the battery up and out of the laptop.
  7. Acer Nitro 5 AN515-53-52FA CMOS Replacement, CMOS: 7 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA CMOS Replacement, CMOS: 7 단계, 이미지 2개 중 2개
    • Locate the CMOS that is under the battery.
  8. Acer Nitro 5 AN515-53-52FA CMOS Replacement: 8 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA CMOS Replacement: 8 단계, 이미지 2개 중 2개
    • Gently unplug the port.
  9. Acer Nitro 5 AN515-53-52FA CMOS Replacement: 9 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA CMOS Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully pull the CMOS Battery, as there is adhesive keeping it attached.
결론
작성자
2다른 기여자 명과 함께
Alfredo Prieto
회원 가입일: 09/01/22
908 평판
안내서 5개를 작성함
Gateway, Team 1-3, Pee Fall 2022 Gateway, Team 1-3, Pee Fall 2022 회원
GCC-PEE-F22S1G3
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 58
지난 30일: 321
전체 시간: 7,840
