주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-53-52FA Fan Replacement
Alfredo Prieto
Alfredo Prieto4 다른 기여자
최종 수정일 February 28, 2023
30 - 55 분
조정
Use this guide to replace the fan in the Acer Nitro 5 AN515-53-52FA, before using this guide open up the computer and use a can of air on the fan.
The fan is the cooling unit of the laptop, without the fans the laptop would not cool and overheat. A broken fan can make uncommon noises, and ruin the performance of the laptop. Dirt or dust could get lodged into the fan forcing them to stop and overheat the laptop.
The Old fans of the laptop can easily be recycled after.
필요한 것
부품
도구
더보기...
  1. Acer Nitro 5 AN515-53-52FA Fan Replacement, Fan: 1 단계, 이미지 1개 중 1개
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up
  2. Acer Nitro 5 AN515-53-52FA Fan Replacement: 2 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Fan Replacement: 3 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
    • Removing the backshell of the laptop will reveal the inside of it.
    • The fan of the laptop is located on the top left of the laptop.
  4. Acer Nitro 5 AN515-53-52FA Fan Replacement: 4 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove the four 9 mm screws securing the fans.
  5. Acer Nitro 5 AN515-53-52FA Fan Replacement: 5 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-52FA Fan Replacement: 5 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-52FA Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Unplug the connectors before taking the fan out.
  6. Acer Nitro 5 AN515-53-52FA Fan Replacement: 6 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-52FA Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Gently remove the fans from the adhesive strip.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alfredo Prieto
회원 가입일: 09/01/22
908 평판
안내서 5개를 작성함
Gateway, Team 1-3, Pee Fall 2022 Gateway, Team 1-3, Pee Fall 2022 회원
GCC-PEE-F22S1G3
4 회원들
안내서 7개를 작성함
댓글 2개
This helped me out. The instructions were completely easy to follow. Thank you so much!
Adam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 75
전체 시간: 1,460
