주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN517-51-56YW Battery Replacement
Jacob Elkins
Jacob Elkins3 다른 기여자
최종 수정일 December 15, 2022
1 - 5 분
쉬움
Use this guide to replace the battery of an Acer Nitro 5 AN517-51-56YW. The AN517 is a gaming laptop that houses a higher-performance battery. Make sure to know exactly which battery type and specifications you will need to replace the battery. If you notice that the battery is swollen, please visit this article on how to identify a swollen battery and what to do.
This guide will help ensure the laptop can start up and will be repaired.
필요한 것
부품
도구
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
더보기...
  1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: 2 단계, 이미지 2개 중 1개 Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Nitro 5 AN517-51-56YW Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jacob Elkins
회원 가입일: 09/15/22
221 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 45
전체 시간: 2,238
