주요 콘텐츠로 건너뛰기
Acer Predator 17 G9-791 Service Panel Replacement
Matthew Shane
Matthew Shane4 다른 기여자
최종 수정일 December 21, 2022
5 분
쉬움
If you need to access the inside of your Acer Predator G9 791, use this guide to begin with replacing the service panel.
Before you begin, make sure that the laptop is fully powered down and disconnected from its charger.
필요한 것
도구
  1. Acer Predator 17 G9-791 Service Panel Replacement, Service Panel: 1 단계, 이미지 1개 중 1개
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Service Panel Replacement: 2 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Service Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Service Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Continue pulling up on the panel to separate it from the laptop and remove it.
결론
작성자
4다른 기여자 명과 함께
Matthew Shane
회원 가입일: 10/25/22
376 평판
안내서 3개를 작성함
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S5G1
5 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 151
