주요 콘텐츠로 건너뛰기
Acer Predator 17 G9-791 Trackpad Replacement
Adeline Slocum
Adeline Slocum3 다른 기여자
최종 수정일 December 21, 2022
20 - 25 분
조정
If your Acer Predator 17 G9-721 trackpad is unresponsive or broken, you may need to take it out and replace it. If the touchpad could potentially be disabled, restart your computer by holding the "Fn" key and press the "F7" key at the same time. If this still does not resolve the issue, use this guide to replace your trackpad.
필요한 것
도구
  1. Acer Predator 17 G9-791 Trackpad Replacement, Service Panel: 1 단계, 이미지 1개 중 1개
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Trackpad Replacement: 2 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Trackpad Replacement: 2 단계, 이미지 2개 중 2개
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Trackpad Replacement: 3 단계, 이미지 1개 중 1개
    • Continue pulling up on the panel to separate it from the laptop and remove it.
  4. Acer Predator 17 G9-791 Trackpad Replacement, Bottom Case: 4 단계, 이미지 3개 중 1개 Acer Predator 17 G9-791 Trackpad Replacement, Bottom Case: 4 단계, 이미지 3개 중 2개 Acer Predator 17 G9-791 Trackpad Replacement, Bottom Case: 4 단계, 이미지 3개 중 3개
    • Remove the nine 4.5 mm Phillips #0 screws from the panel.
    • Remove four 14 mm Phillips #0 screws.
    • Remove six 7 mm Phillips #0 screws.
  5. Acer Predator 17 G9-791 Trackpad Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
  6. Acer Predator 17 G9-791 Trackpad Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
  7. Acer Predator 17 G9-791 Trackpad Replacement: 7 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Trackpad Replacement: 7 단계, 이미지 2개 중 2개
    • Pry up on the edges of the bottom cover and lift the bottom case off of the device.
  8. Acer Predator 17 G9-791 Trackpad Replacement, Battery: 8 단계, 이미지 1개 중 1개
    • Remove the six 4 mm Phillips #0 screws from the battery.
  9. Acer Predator 17 G9-791 Trackpad Replacement: 9 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Trackpad Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the battery connector from the motherboard.
  10. Acer Predator 17 G9-791 Trackpad Replacement: 10 단계, 이미지 1개 중 1개
    • Gently lift the battery and remove it from the device.
  11. Acer Predator 17 G9-791 Trackpad Replacement, Trackpad: 11 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Trackpad Replacement, Trackpad: 11 단계, 이미지 2개 중 2개
    • Remove the seven 4 mm Phillips #0 screws.
  12. Acer Predator 17 G9-791 Trackpad Replacement: 12 단계, 이미지 2개 중 1개 Acer Predator 17 G9-791 Trackpad Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the connector by flipping the black lock bar up and removing the pulling it out.
    • Peel back the tape from the metal button assembly on the bottom and the tape connecting the trackpad to the device at the top.
  13. Acer Predator 17 G9-791 Trackpad Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the metal button assembly.
  14. Acer Predator 17 G9-791 Trackpad Replacement: 14 단계, 이미지 1개 중 1개
    • Flip the black lock bar up and remove the connector on the left.
  15. Acer Predator 17 G9-791 Trackpad Replacement: 15 단계, 이미지 3개 중 1개 Acer Predator 17 G9-791 Trackpad Replacement: 15 단계, 이미지 3개 중 2개 Acer Predator 17 G9-791 Trackpad Replacement: 15 단계, 이미지 3개 중 3개
    • Using a spudger, pry the trackpad up and remove it from the device.
    • There is an adhesive holding the trackpad down that must be pulled against.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adeline Slocum
회원 가입일: 10/25/22
304 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S5G1
5 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 6
전체 시간: 389
