주요 콘텐츠로 건너뛰기
Acer Swift X N20C12 Battery Replacement
Abrar
Abrar5 다른 기여자
최종 수정일 February 14, 2025
20 - 30 분
조정
더 많은 이미지가 필요함
If you noticed your laptop's battery not lasting as long as it used to or if it takes long to charge and suddenly dies even when it shows some power left and if your battery is swell, these annoyances often mean your battery is damaged. High temperatures can speed up this process, causing the battery's capacity to drop faster. Let's follow the guide to replacing the battery.
필요한 것
부품
도구
더보기...
  1. Acer Swift X N20C12 Battery Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Grasp the battery connector and pull it directly out of its socket.
    • Use a Phillips #1 screwdriver to remove the two 4.8 mm screws that secure the battery.
  4. Acer Swift X N20C12 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the battery up and out of the chassis.
결론
작성자
5다른 기여자 명과 함께
Abrar
회원 가입일: 09/08/23
472 평판
안내서 5개를 작성함
Gateway, Team 1-2, Pee Fall 2023 Gateway, Team 1-2, Pee Fall 2023 회원
GCC-PEE-F23S1G2
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 82
전체 시간: 951
