주요 콘텐츠로 건너뛰기
Adjusting the Rear Derailleur
Travis Tonder
Travis Tonder7 다른 기여자
최종 수정일 August 7, 2014
30 - 45 분
조정
The derailleur is your bike’s gear shifting device. When you adjust the shifter on your handlebars, the derailleur pushes your bike chain to the next gear over, and then adjusts the length of the chain to accommodate the change in gear size.
There are many ways to adjust a derailleur. For small adjustments, there is no need to remove the chain or the derailleur. This guide demonstrates one way to adjust the derailleur to the proper position after removing the derailleur and chain for maintenance.
In steps 2 and 3, we adjust the high and low end adjustment stops, which set the maximum inward and outward distance that the derailleur can move the bike chain. Setting these boundaries prevents the derailleur from shifting the chain off of the sprockets and onto the axle.
By putting the shifter in the highest gear in step 4, the cable is let out as far as possible when we clamp down on it. This ensures that all slack is removed from the line.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Adjusting the Rear Derailleur, Bike Chain Removal: 1 단계, 이미지 2개 중 1개 Adjusting the Rear Derailleur, Bike Chain Removal: 1 단계, 이미지 2개 중 2개
    • Slide the chain cutting tool onto the desired link.
    • Align the push pin of the tool with the pin on the chain, and tighten the tool until the pin protrudes out the other side without falling all the way out.
  2. Adjusting the Rear Derailleur: 2 단계, 이미지 1개 중 1개
    • Stop pushing the pin out when it is just held in by the outer link, so it doesn't fall all the way out. You will still be able to separate the links.
    • Repeat the previous step to take off sections of links.
  3. Adjusting the Rear Derailleur, Rear Derailleur: 3 단계, 이미지 2개 중 1개 Adjusting the Rear Derailleur, Rear Derailleur: 3 단계, 이미지 2개 중 2개
    • Bolt the derailleur to the mounting tab with an Allen wrench.
    • Be careful not to over-tighten the steel bolt, as this can strip the aluminum mounting tab.
  4. Adjusting the Rear Derailleur: 4 단계, 이미지 3개 중 1개 Adjusting the Rear Derailleur: 4 단계, 이미지 3개 중 2개 Adjusting the Rear Derailleur: 4 단계, 이미지 3개 중 3개
    • Shift the rear derailleur into the highest gear(smallest sprocket).
    • Align the rear guide sprocket of the derailleur with the highest gear (smallest sprocket), by tightening or loosening the screw labeled "H".
  5. Adjusting the Rear Derailleur: 5 단계, 이미지 3개 중 1개 Adjusting the Rear Derailleur: 5 단계, 이미지 3개 중 2개 Adjusting the Rear Derailleur: 5 단계, 이미지 3개 중 3개
    • Shift the rear derailleur into the lowest gear(largest sprocket).
    • Align the rear guide sprocket of the derailleur with the lowest gear(largest sprocket), by tightening or loosening the screw labeled "L".
  6. Adjusting the Rear Derailleur: 6 단계, 이미지 2개 중 1개 Adjusting the Rear Derailleur: 6 단계, 이미지 2개 중 2개
    • Shift the bike into the highest numbered gear.
    • Slide the cable through the barrel adjuster screw until the cable housing bottoms out.
    • Pull the slack out of the cable while clamping it down with the nut that is attached to the derailleur.
  7. Adjusting the Rear Derailleur: 7 단계, 이미지 3개 중 1개 Adjusting the Rear Derailleur: 7 단계, 이미지 3개 중 2개 Adjusting the Rear Derailleur: 7 단계, 이미지 3개 중 3개
    • Route the chain around the chain rings, cassette, and derailleur.
    • Reconnect both ends of the chain using a master link or a chain cutter tool.
    • See the chain connection guide.
  8. Adjusting the Rear Derailleur: 8 단계, 이미지 1개 중 1개
    • Fine tune the derailleur by tightening or loosening the barrel adjuster screw. Loosening this screw causes the derailleur to move slightly towards a larger sprocket, while tightening it moves the derailler towards a smaller sprocket.
    • Shift through each gear while pedaling. The derailleur should move the chain one gear over each time you shift up or down.
    • If the chain skips or makes noise when you are not shifting, use the barrel adjustment screw to fine tune the derailleur alignment.
    • Repeat the previous steps until the derailleur shifts smoothly and makes a minimal amount of noise.
결론
For future adjustments it is likely that you will only need to adjust the barrel adjuster screw for fine adjustment.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Travis Tonder
회원 가입일: 10/05/10
3,210 평판
안내서 4개를 작성함
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 회원
CPSU-MANESS-F10S5G13
4 회원들
안내서 17개를 작성함
댓글 3개
Thanks Travis! I was a little unsure about how to do this without ruining my derailleur! Thx alot!
Tim - 답글
Thanks the direction is simple enough.
Robert - 답글
I always wondered how to align the guide wheel and the sprockets. Now I have a better idea.
Edwin Icogo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 78
전체 시간: 22,344
