주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Afterglow Wireless PS3 Controller Vibration Motor Replacement
필요한 것
  1. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    댓글 쓰기
  2. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: 2 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: 2 단계, 이미지 2개 중 2개
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    댓글 쓰기
  3. Afterglow Wireless PS3 Controller Vibration Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    댓글 쓰기
  4. Afterglow Wireless PS3 Controller Vibration Motor Replacement: 4 단계, 이미지 3개 중 1개 Afterglow Wireless PS3 Controller Vibration Motor Replacement: 4 단계, 이미지 3개 중 2개 Afterglow Wireless PS3 Controller Vibration Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so that the vibration motor wire connections are accessible.
    댓글 쓰기
  5. Afterglow Wireless PS3 Controller Vibration Motor Replacement: 5 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Vibration Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Pull both vibration motors straight up from their holding place.
    댓글 쓰기
  6. Afterglow Wireless PS3 Controller Vibration Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Use the soldering tool to heat the solder connecting the red and black vibration motor wires to the motherboard to detach the vibration motors.
    • Use this guide for further details on how to solder.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Natalie Cox
회원 가입일: 02/17/17
207 평판
안내서 2개를 작성함
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G5
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 33
전체 시간: 1,504
