주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alcatel Jitterbug Smart Charging Port Replacement
필요한 것
  1. Alcatel Jitterbug Smart Charging Port Replacement, Battery: 1 단계, 이미지 2개 중 1개 Alcatel Jitterbug Smart Charging Port Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
    댓글 쓰기
  2. Alcatel Jitterbug Smart Charging Port Replacement: 2 단계, 이미지 3개 중 1개 Alcatel Jitterbug Smart Charging Port Replacement: 2 단계, 이미지 3개 중 2개 Alcatel Jitterbug Smart Charging Port Replacement: 2 단계, 이미지 3개 중 3개
    • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
    댓글 쓰기
  3. Alcatel Jitterbug Smart Charging Port Replacement: 3 단계, 이미지 2개 중 1개 Alcatel Jitterbug Smart Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
    댓글 쓰기
  4. Alcatel Jitterbug Smart Charging Port Replacement: 4 단계, 이미지 2개 중 1개 Alcatel Jitterbug Smart Charging Port Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
    댓글 쓰기
  5. Alcatel Jitterbug Smart Charging Port Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Alcatel Jitterbug Smart Charging Port Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Alcatel Jitterbug Smart Charging Port Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
    댓글 쓰기
  6. Alcatel Jitterbug Smart Charging Port Replacement: 6 단계, 이미지 2개 중 1개 Alcatel Jitterbug Smart Charging Port Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to pull the black ribbon connector from its port.
    • Use a metal Spudger to gentle remove the speaker that glued at the bottom left of the phone.
    • Be careful to avoid damage the black connector or the wire connect the speaker to motherboard.
    댓글 쓰기
  7. Alcatel Jitterbug Smart Charging Port Replacement: 7 단계, 이미지 2개 중 1개 Alcatel Jitterbug Smart Charging Port Replacement: 7 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, begin to gently pry the motherboard, away from the display assembly.
    • The motherboard will freely remove.
    댓글 쓰기
  8. Alcatel Jitterbug Smart Charging Port Replacement, Charging Port: 8 단계, 이미지 2개 중 1개 Alcatel Jitterbug Smart Charging Port Replacement, Charging Port: 8 단계, 이미지 2개 중 2개
    • Flip the motherboard over and desolder the charging port pin connecting on the motherboard.
    • Once pins desolder, pull off the charging port.
    • If you need helps on solder/desolder, here is the link to the soldering skills guide.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Minyu Zhang
회원 가입일: 02/13/18
181 평판
안내서 2개를 작성함
USF Tampa, Team S11-G4, Cheng Spring 2018 USF Tampa, Team S11-G4, Cheng Spring 2018 회원
USFT-CHENG-S18S11G4
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 32
전체 시간: 2,032
