주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware AW610M Side Button Replacement
필요한 것
    1. Alienware AW610M Side Button Replacement, Battery: 1 단계, 이미지 3개 중 1개 Alienware AW610M Side Button Replacement, Battery: 1 단계, 이미지 3개 중 2개 Alienware AW610M Side Button Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Power off the mouse and disconnect any wired connections.
      댓글 쓰기
    2. Alienware AW610M Side Button Replacement: 2 단계, 이미지 2개 중 1개 Alienware AW610M Side Button Replacement: 2 단계, 이미지 2개 중 2개
      • Use a spudger to gently lift and remove the old mouse feet.
      • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
      • Be careful not to scratch the mouse surface or damage the plastic housing.
      댓글 쓰기
    3. Alienware AW610M Side Button Replacement: 3 단계, 이미지 2개 중 1개 Alienware AW610M Side Button Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
      댓글 쓰기
    4. Alienware AW610M Side Button Replacement: 4 단계, 이미지 2개 중 1개 Alienware AW610M Side Button Replacement: 4 단계, 이미지 2개 중 2개
      • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
      • Don't pull the halves completely apart, as internal wires still connect them.
      댓글 쓰기
    5. Alienware AW610M Side Button Replacement: 5 단계, 이미지 3개 중 1개 Alienware AW610M Side Button Replacement: 5 단계, 이미지 3개 중 2개 Alienware AW610M Side Button Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the battery pack inside the mouse.
      • If you are having trouble, use a small flat tool to help ease it out.
      • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
      댓글 쓰기
    6. Alienware AW610M Side Button Replacement: 6 단계, 이미지 2개 중 1개 Alienware AW610M Side Button Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
      • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
      댓글 쓰기
    1. Alienware AW610M Side Button Replacement, Side Button: 7 단계, 이미지 2개 중 1개 Alienware AW610M Side Button Replacement, Side Button: 7 단계, 이미지 2개 중 2개
      • Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
      • Detach the cable connector, and remove the scroll wheel.
      • Gently detach the last connector using your fingers.
      • Be careful when unplugging all connectors to prevent tearing them.
      댓글 쓰기
    2. Alienware AW610M Side Button Replacement: 8 단계, 이미지 1개 중 1개
      • Turn the large shell casing so that the inside faces you.
      • Using a Phillips #1 screwdriver, remove six 5.4 mm screws.
      댓글 쓰기
    3. Alienware AW610M Side Button Replacement: 9 단계, 이미지 2개 중 1개 Alienware AW610M Side Button Replacement: 9 단계, 이미지 2개 중 2개
      • Using your fingers, disconnect the plastic tab in the middle of the large shell casing to access the side buttons.
      댓글 쓰기
    4. Alienware AW610M Side Button Replacement: 10 단계, 이미지 3개 중 1개 Alienware AW610M Side Button Replacement: 10 단계, 이미지 3개 중 2개 Alienware AW610M Side Button Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the side button on the inner side of the wall using a plastic opening tool.
      • Be gentle prying the side buttons off to avoid breaking them.
      • When reassembling, position the new side button assembly into the slot, aligning it with tabs. Snap it securely into place using a plastic opening tool or your fingers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Darby Brandt
회원 가입일: 09/24/25
391 평판
안내서 2개를 작성함
Texas Tech, Team 46-4, Johansen Fall 2025 Texas Tech, Team 46-4, Johansen Fall 2025 회원
TTU-JOHANSEN-F25S46G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 43
전체 시간: 257
