주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alldaymall A88X Battery Replacement
필요한 것
    1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: 1 단계, 이미지 3개 중 1개 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: 1 단계, 이미지 3개 중 2개 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: 1 단계, 이미지 3개 중 3개
      • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
      • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
      • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
      댓글 쓰기
    2. Alldaymall A88X Battery Replacement: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
      • When removing the speaker, make sure not to disconnect the wires in any way.
      • After the speaker has been removed, place the rear panel aside.
      댓글 쓰기
    1. Alldaymall A88X Battery Replacement, Battery: 3 단계, 이미지 3개 중 1개 Alldaymall A88X Battery Replacement, Battery: 3 단계, 이미지 3개 중 2개 Alldaymall A88X Battery Replacement, Battery: 3 단계, 이미지 3개 중 3개
      • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
      • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to server any of these.
      댓글 쓰기
    2. Alldaymall A88X Battery Replacement: 4 단계, 이미지 3개 중 1개 Alldaymall A88X Battery Replacement: 4 단계, 이미지 3개 중 2개 Alldaymall A88X Battery Replacement: 4 단계, 이미지 3개 중 3개
      • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
      • After the battery is separated from the panel make sure to place it face down above the tablet itself.
      • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
      댓글 쓰기
    3. Alldaymall A88X Battery Replacement: 5 단계, 이미지 2개 중 1개 Alldaymall A88X Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Desolder the wires that connect the battery to the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex
회원 가입일: 02/10/16
101 평판
안내서 1개를 작성함
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016 회원
USFT-LACY-S16S4G1
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 1,622
