주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Altec Lansing inMotion iM9 Tweeter Replacement
필요한 것
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Gently push down on the two tabs at the top of the battery door.
      • While holding them down, slowly pull the door towards you.
      댓글 쓰기
    2. Altec Lansing inMotion iM9 Tweeter Replacement: 2 단계, 이미지 1개 중 1개
      • Once the door is open, use your hand to pull out the four batteries.
      댓글 쓰기
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Volume and Power Buttons: 3 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Tweeter Replacement, Volume and Power Buttons: 3 단계, 이미지 2개 중 2개
      • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
      • Start in the middle and work your way around the perimeter.
      댓글 쓰기
    2. Altec Lansing inMotion iM9 Tweeter Replacement: 4 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Tweeter Replacement: 4 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
      • Also remove the single 7mm screw from the power button circuit board on the opposite side.
      • There will be a little plastic piece under the eject button that you can just remove and set aside.
      댓글 쓰기
    3. Altec Lansing inMotion iM9 Tweeter Replacement: 5 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Tweeter Replacement: 5 단계, 이미지 2개 중 2개
      • Desolder the three solders joints connecting the wires to the volume button circuit board.
      • Do the same to the power button circuit board on the other side (the board with only one screw).
      • Pull out the wires using a lot of force.
      • If you are not familiar or comfortable with soldering, use this guide
      댓글 쓰기
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Case Opening: 6 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Tweeter Replacement, Case Opening: 6 단계, 이미지 2개 중 2개
      • Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
      • It is best to start from the top or bottom, then work your way around if it has not popped out yet.
      • Remove the silver lining.
      댓글 쓰기
    2. Altec Lansing inMotion iM9 Tweeter Replacement: 7 단계, 이미지 2개 중 1개 Altec Lansing inMotion iM9 Tweeter Replacement: 7 단계, 이미지 2개 중 2개
      • Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
      • Once loose, lift up the metal mesh.
      댓글 쓰기
    3. Altec Lansing inMotion iM9 Tweeter Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
      • Remove the 7mm screw with the Phillips #1 Screwdriver.
      댓글 쓰기
    4. Altec Lansing inMotion iM9 Tweeter Replacement: 9 단계, 이미지 1개 중 1개
      • Carefully separate the front and back case plates at a corner of the speaker.
      • Lots of cables are still connected, so be very gentle when separating case plates.
      댓글 쓰기
    5. Altec Lansing inMotion iM9 Tweeter Replacement: 10 단계, 이미지 1개 중 1개
      • Guide the white button cables through the hole on the top of speaker case.
      댓글 쓰기
    6. Altec Lansing inMotion iM9 Tweeter Replacement: 11 단계, 이미지 1개 중 1개
      • Use your fingers to peel the glue off of the red and black cables.
      댓글 쓰기
    7. Altec Lansing inMotion iM9 Tweeter Replacement: 12 단계, 이미지 1개 중 1개
      • Careful not to touch the green capacitors or you might shock yourself.
      댓글 쓰기
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Tweeter: 13 단계, 이미지 1개 중 1개
      • Remove the speaker cables by desoldering the two solder joints on opposite sides of the tweeter.
      댓글 쓰기
    2. Altec Lansing inMotion iM9 Tweeter Replacement: 14 단계, 이미지 1개 중 1개
      • To fully remove the tweeter from the device, unscrew the two 7mm screws and the tweeter will be free.
      댓글 쓰기
    3. Altec Lansing inMotion iM9 Tweeter Replacement: 15 단계, 이미지 1개 중 1개
      • Follow the previous instructions to remove the second tweeter on the opposite side of the speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Shaun Steele
회원 가입일: 02/02/15
279 평판
안내서 2개를 작성함
Cal Poly, Team 17-33, Amido Winter 2015 Cal Poly, Team 17-33, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G33
4 회원들
안내서 14개를 작성함
1가이드 댓글
Where do you buy the replacement tweeters?
Fred Schneider - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 33
전체 시간: 1,329
