주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Kindle 8 Battery Replacement
필요한 것
  1. Amazon Kindle 8 Battery Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 Amazon Kindle 8 Battery Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the front cover gently so that it is not cracked.
    댓글 쓰기
  2. Amazon Kindle 8 Battery Replacement: 2 단계, 이미지 2개 중 1개 Amazon Kindle 8 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the spudger between the inner front cover and the screen.
    • Gently work your way around to loosen the inner front cover.
    • Carefully lift the inner front cover from the device.
    댓글 쓰기
  3. Amazon Kindle 8 Battery Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Amazon Kindle 8 Battery Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
    댓글 쓰기
  4. Amazon Kindle 8 Battery Replacement: 4 단계, 이미지 2개 중 1개 Amazon Kindle 8 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the screen and motherboard from the back cover.
    댓글 쓰기
  5. Amazon Kindle 8 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Pinch the clips on the battery and disconnect the battery connector from its socket.
    댓글 쓰기
  6. Amazon Kindle 8 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the halberd spudger between the motherboard and battery.
    • Take care not to bend, twist, or puncture the battery.
    • Slowly move the spudger around the battery and pry it off.
    • The battery is glued in place, so don't be afraid to use some moderate force.
    댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Luke
회원 가입일: 09/25/24
444 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 72
지난 30일: 340
전체 시간: 5,827
