주요 콘텐츠로 건너뛰기
Amazon Kindle DX SIM Card Replacement
Hassan Haseeb
Hassan Haseeb7 다른 기여자
최종 수정일 August 25, 2024
15 - 30 분
조정
The Kindle DX e-reader was introduced by Amazon in 2009.  It comes with a QWERTY keyboard and a d-pad.  The DX model comes with free worldwide 3G internet access that requires a SIM card within the device.
If the SIM card malfunctions in a Kindle DX, the user will not be able to download e-books via the 3G network.
This guide will provide step by step instructions to replace the SIM card.
 Warning: Turn off the Kindle DX e-reader before replacing the SIM card.
필요한 것
도구
더보기...
  1. Amazon Kindle DX SIM Card Replacement, Sim Card: 1 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to push against the top part of the e-reader to open the device.
  2. Amazon Kindle DX SIM Card Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the plastic top.
  3. Amazon Kindle DX SIM Card Replacement: 3 단계, 이미지 2개 중 1개 Amazon Kindle DX SIM Card Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the two small screws on each corner.
    • Remove the two 40mm screws with a Phillips #0 screwdriver.
  4. Amazon Kindle DX SIM Card Replacement: 4 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to take the off the metal plate.
  5. Amazon Kindle DX SIM Card Replacement: 5 단계, 이미지 1개 중 1개
    • Locate and remove the SIM card slot.
  6. Amazon Kindle DX SIM Card Replacement: 6 단계, 이미지 1개 중 1개
    • Use the spudger to push the metal lid backwards, as pictured.
  7. Amazon Kindle DX SIM Card Replacement: 7 단계, 이미지 1개 중 1개
    • Open the lid to replace the SIM card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Hassan Haseeb
회원 가입일: 09/28/16
189 평판
안내서 1개를 작성함
USF Tampa, Team 1-5, Cagle Fall 2016 USF Tampa, Team 1-5, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G5
3 회원들
안내서 10개를 작성함
댓글 3개
Need to do this with a kindle I have is does it need to be replaced with a 3G sim
Melanie Tague - 답글
I have 10 kindle Docs, first or second generation. I am too old to use the new kindles, fire, paperwhites. Can I make my old kindles work? I have them for different genres, 3200 books total. Please before I’m too old to care. Thank you for your time. I’m desperate.
Lilli Bean
Lillibean - 답글
DXs. Spellcheck messed up. Not me!
Lillibean - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 57
전체 시간: 3,610
