Amazon Kindle Fire 7th Generation Battery Replacement
Does your Kindle Fire 7 need its battery replaced? This guide will teach you how in step-by-step format. Before you begin, you will need a tool to pry the tablet open. This guide will be using the iFixit Opening Tool, on sale for $1.99. You will also need a #00 Phillips screwdriver.
Insert the plastic prying tool along the edge of the tablet, where the back cover meets the screen's bezel.
Carefully work your way around the edges to free all of the clips that secure the back cover in place.
Remove the two screws that secure the battery connector cover in place with a #00 Phillips screwdriver.
Lift the battery connector cover off.
다른 3명이 해당 안내서를 완성하였습니다.
